Fecha actual Mar Ago 25, 2026 4:57 pm
 Asunto: Dudas al montar un radio
NotaPublicado: Mar Feb 09, 2010 7:14 pm
New Beetle:Vortex Blue 1.8T
le monte un radio sony pero nose donde ponerle el cable de ground....seberia ponerselo o no? ahora mismo no lo tiene puesto pq no conseguir lata pa ponerselo y como kiera prende el radio de lo mas bien.....kiciera ke alguien me oriente a ver ke deberia hacer.....gracias
NEW BEETLE VORTEX BLUE 1.8T
 Asunto: Re: dudas al montar un radio
NotaPublicado: Mar Feb 09, 2010 11:54 pm
Volkswagon Radio Wire Harnesses
Typical VW Typical New Radio
Pin What It Is In Dash Wire Color Equivalent Wire Color
A Right Rear Speaker (+) Blue w/ Green Stripe Purple
B Right Rear Speaker (-) Brown w/ Red Stripe Purple w/ Black Stripe
C Right Front Speaker (+) Red w/ White Stripe Gray
D Right Front Speaker (-) Brown w/ White Stripe Gray w/ Black Stripe
E Left Front Speaker (+) Black White
F Left Front Speaker (-) Brown w/ Blue Stripe White w/ Black Stripe\
G Left Rear Speaker (+) Blue w/ Green Stripe Green
H Left Rear Speaker (-) Brown w/ Red Stripe Green w/ Black Stripe
I Do Not Use
J Do Not Use
K Do Not Use
L +12 Volt Ignition Wire Brown w/ Red Stripe Red
M Do Not Use
N Dash Light Dimmer Wire Gray w/ Blue Stripe check for availability
O +12 Volt Battery Wire Thick Red w/ White Stripe Yellow
P Ground Wire Thick Brown Wire Black
o esta opcion
A Right Rear Speaker (+) Blue Purple
B Right Rear Speaker (-) Tan w/ Blue Stripe Purple w/ Black Stripe
C Right Front Speaker (+) Red Gray
D Right Front Speaker (-) Tan w/ Red Stripe Gray w/ Black Stripe
E Left Front Speaker (+) Blue w/ White Stripe White
F Left Front Speaker (-) Tan w/ White Stripe White w/ Black Stripe\
G Left Rear Speaker (+) Red w/ Green Stripe Green
H Left Rear Speaker (-) Tan w/ Green Stripe Green w/ Black Stripe
I Do Not Use
J Do Not Use
K VW Amp Turn On Wire - Connect To New Radios Blue Power Antenna Wire
L +12 Volt Ignition Wire Yellow w/ Red Stripe Red
M Power Antenna Turn On Wire - Connect To New Radios Blue Power Antenna Wire
P Ground Wire Thick Tan Wire Black
VERIFICA ESTAS GRAFICAS A VER SI LO MONTASTES ASI
NotaPublicado: Mié Feb 10, 2010 9:54 am
creo ke esta asi lo unico ke no entiendo si hay ke ponerle el cable de ground o no....
NotaPublicado: Jue Feb 11, 2010 8:06 pm
bueno si esta asi pues esta puesto el ground,fijate que debe ser el tan, ese es como entre anaranjado y marron, ahi va el negro del nuevo radio
NotaPublicado: Vie Feb 12, 2010 7:31 pm
:boricua: Muy buena info, las letras y codigos... :thumbup:
