| Dudas al montar un radio http://newbeetlepr.com/viewtopic.php?f=15&t=2332 |
| Autor: | bryantoski [ Mar Feb 09, 2010 7:14 pm ] |
| Asunto: | Dudas al montar un radio |
le monte un radio sony pero nose donde ponerle el cable de ground....seberia ponerselo o no? ahora mismo no lo tiene puesto pq no conseguir lata pa ponerselo y como kiera prende el radio de lo mas bien.....kiciera ke alguien me oriente a ver ke deberia hacer.....gracias |
| Autor: | pmq259 [ Mar Feb 09, 2010 11:54 pm ] |
| Asunto: | Re: dudas al montar un radio |
Volkswagon Radio Wire Harnesses Typical VW Typical New Radio Pin What It Is In Dash Wire Color Equivalent Wire Color A Right Rear Speaker (+) Blue w/ Green Stripe Purple B Right Rear Speaker (-) Brown w/ Red Stripe Purple w/ Black Stripe C Right Front Speaker (+) Red w/ White Stripe Gray D Right Front Speaker (-) Brown w/ White Stripe Gray w/ Black Stripe E Left Front Speaker (+) Black White F Left Front Speaker (-) Brown w/ Blue Stripe White w/ Black Stripe\ G Left Rear Speaker (+) Blue w/ Green Stripe Green H Left Rear Speaker (-) Brown w/ Red Stripe Green w/ Black Stripe I Do Not Use J Do Not Use K Do Not Use L +12 Volt Ignition Wire Brown w/ Red Stripe Red M Do Not Use N Dash Light Dimmer Wire Gray w/ Blue Stripe check for availability O +12 Volt Battery Wire Thick Red w/ White Stripe Yellow P Ground Wire Thick Brown Wire Black o esta opcion A Right Rear Speaker (+) Blue Purple B Right Rear Speaker (-) Tan w/ Blue Stripe Purple w/ Black Stripe C Right Front Speaker (+) Red Gray D Right Front Speaker (-) Tan w/ Red Stripe Gray w/ Black Stripe E Left Front Speaker (+) Blue w/ White Stripe White F Left Front Speaker (-) Tan w/ White Stripe White w/ Black Stripe\ G Left Rear Speaker (+) Red w/ Green Stripe Green H Left Rear Speaker (-) Tan w/ Green Stripe Green w/ Black Stripe I Do Not Use J Do Not Use K VW Amp Turn On Wire - Connect To New Radios Blue Power Antenna Wire L +12 Volt Ignition Wire Yellow w/ Red Stripe Red M Power Antenna Turn On Wire - Connect To New Radios Blue Power Antenna Wire N Dash Light Dimmer Wire Gray w/ Blue Stripe check for availability O +12 Volt Battery Wire Thick Red w/ White Stripe Yellow P Ground Wire Thick Tan Wire Black VERIFICA ESTAS GRAFICAS A VER SI LO MONTASTES ASI |
| Autor: | bryantoski [ Mié Feb 10, 2010 9:54 am ] |
creo ke esta asi lo unico ke no entiendo si hay ke ponerle el cable de ground o no.... |
| Autor: | pmq259 [ Jue Feb 11, 2010 8:06 pm ] |
bueno si esta asi pues esta puesto el ground,fijate que debe ser el tan, ese es como entre anaranjado y marron, ahi va el negro del nuevo radio |
| Autor: | RAMSAYO [ Vie Feb 12, 2010 7:31 pm ] |
Muy buena info, las letras y codigos... |
